News:
Main Menu
Acopos 1022 - HMI states "lag error stop limit exceeded"
Started by s13t0ttz, March 29, 2025, 08:43:PM
Previous topic - Next topic
s13t0ttz
Hello Everyone,
My name is Thor.
I have a machine from Germany made around 2006 which is using aa Acopos 1022 drive to operate a paper cutting knife. There is an HMI installed. When running the machine, the paper cutting knife cannot make it through the paper and an error shows up on the HMI. There's no error on the drive.
The error is: Lag error stop limit exceeded
I want to know if it is possible to connect to the drive with a computer and see if I can make adjustments to correct this error.
Let me know if you want any other information and I'll supply it, if possible.
Sincerely,
Thor
benklassne
Sounds like a "maximum lag error" caused by servo gain needing adjustment or you simply have a bad encoder or cable.
