Obsolete Control Coils
The control coil is an integral part of industrial manufacturing today. Precise machinery control has revolutionized the way we manaufacture just about every product in an industrial environment and the control coil, in many cases, is a critical part of that system. Unfortunately, a small component such as an obsolete control coil can result in substantial down-time.
When they operate properly, they provide us with the ability to open and close switches, relays, solenoids, and other electro-mechanical devices. When they fail, they can leave us helpless with machinery down-time and in a costly situation on the shop floor.
Control Coil Troubleshooting Tips | Search eBay for Used Control Coil | Control Coil in our Forum
Control Coils Trackdown and Troubleshooting
Fortunately, control coil problems can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete control coil in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available industrial control coils, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradley control coils, Westinghouse control coils, Square D control coils, or obsolete GE control coils listed daily. Have you ever installed the wrong voltage of control coil? Most of us have at one time or another. An obsolete control can be a real headache if you can't locate a direct replacement.
These coils are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
replace obsolete Control CoilsMachine downtime due to an obsolete control coil is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular control coil is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Control Coil
search for used control coils ul class="floatlist">
  • Used Control Coils
  • 480V Control Coils
  • 24VDC Control Coils
  • 240VDC Control Coils
  • Used DC Control Coils
  • Cutler Hammer Control Coils
  • Used GE Control Coils
  • Siemens Control Coils
  • Square D Control Coils
  • Used Relay Control Coils
  • Westinghouse Control Coils
  • Search eBay Listings →
    Search for Low Cost Control Coils
    Search the Forum for Control Coil Q & A
    We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage control coils, to list them at OI. Ad creation takes only a few minutes and is free of charge.
    We are a technology based organization. All information regarding control coils has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
    See also: DC Magnetic Motor Controllers | Contactors | Relays | Stepper Motors | Stepping Motors | PLC Hardware | Motor Inverters | PLC Racks | Vintage Breakers | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps | Electic Motor Tachs
