Obsolete Contactor Coils
The contactor, along with its operating coil, is an integral part of industrial manufacturing today. Precise machinery and motor control has revolutionized the way we manufacture just about every product in an industrial environment and the contactor coil, in most cases, is a critical part of that system. However, obsolete contactor coils open up a new page in the book of down-time.
When they operate properly, they provide us with the ability to isolate and step up power to motors and other higher current devices using a variety of control voltages. When they fail, they can leave us helpless in a costly situation on the factory floor.
Contactor Coil Troubleshooting Tips | Search eBay for Used Contactor Coil | Contactor Coil in our Forum
Contactor Coil Trackdown and Troubleshooting
Fortunately, contactor coil problems can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete contactor coil in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available industrial contactor coils, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradley contactor coils, Westinghouse contactor coils, Square D contactor coils, or obsolete GE contactor coils listed daily. Many times you can stumble on vintage Cutler Hammer coils or even coils with less popular voltages like 48V, 250V, 300V, or 480V.
These parts are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
replace obsolete Contactor CoilsMachine downtime due to an obsolete contactor coil is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular contactor coil is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Contactor Coil
search for used contactor coils
Search for Low Cost Coils
Search the Forum for Contactor Coil Q & A
We are a technology based organization. All parts and information regarding contactor coils has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
We also posted a contactor troubleshooting guide for those who need help diagnosing a problem.
See also: DC Magnetic Motor Controllers | Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | Proximity Sensors | PLC Hardware | Variable Frequency Drives | Motor Inverters | PLC Racks | Vintage Breakers | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps
