home About Forum Troubleshooting Used Parts search menu
Obsolete Soft Starters
The soft starter is an integral part of industrial manufacturing today. Precision motor control has revolutionized the way we make just about everything in an industrial environment. When they operate properly, they provide us with a controlled motor start and more energy efficient motor operation. When they fail, they can leave us helpless in a bad situation on the shop floor. However, obsolete soft starters open up a new page in the book of down-time.
Soft Starters Troubleshooting Tips | Search eBay for Used Soft Starters | Soft Starters in our Forum
Soft Starter Troubleshooting
Fortunately, soft starter problems can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete soft starter in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available industrial soft starters, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradley soft starters, Westinghouse soft starters, Square D soft starters, or obsolete GE soft starters listed daily. It's unfortunate that so many industrial control parts, including soft starters, find their way into obsoletion so quickly. These parts are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
obsolete Soft StartersMachine downtime due to an obsolete soft starter is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular soft starter is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Soft Starters
search for used soft starters
Search for Low Cost Soft Starters
Our maintenance forum is jam packed with troubleshooting questions and answer, historical data, and general conversation on almost any topic . Forums are broken down into the maintenance saloon, troubleshooting 101, electrical and electronics, mechanical issues, and the classified ads.SMF file version (2.1.2) does not match SMF database version (2.1.7).
Run the SMF upgrader to fix this.
More information.
Search the Forum for Soft Starters Q & A
We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage soft starters, to list them at OI. Ad creation takes only a few minutes and is free of charge.
We are a technology based organization. All information regarding soft starters has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: DC Magnetic Motor Starters | Contactors | Relays | PLC Hardware | Variable Frequency Drives | Inverters | PLC Racks | Pneumatic Valves | Hydraulic Valves | Encoders | Resolvers | Pulse Coders | Reversing Starters | Variable Speed Drives | Contactor Coils | Control Coils | Gear Motors | Chuck Parts | Relay Solenoids | Solenoids | Varidrive Parts | Temperature Controllers | Servo Amplifiers | Motor Tachometers
