Obsolete Pulse Coders
The pulse coder is an integral part of industrial manufacturing today. Precision motor control has revolutionized the way we make just about everything in an industrial environment. When they operate properly, they provide us with a controlled motor start and precise position control. When they fail, they can leave us helpless in a costly situation on the shop floor. However, obsolete pulse coder open up a new page in the book of down-time.
Pulse Coder Troubleshooting Tips | Search eBay for Used Pulse Coder | Pulse Coder in our Forum
OI is user supported. When you buy through our site, we may earn a small affiliate commission, our full disclosure is here.Pulse Coder Troubleshooting
Fortunately, pulse coder problems can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete pulse coder in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available industrial Pulse Coders, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradly Pulse Coders, Westinghouse Pulse Coders, Square D Pulse Coders, or obsolete GE Pulse Coders listed daily.
These parts are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
Machine downtime due to an obsolete pulse coder is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular pulse coder is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Pulse Coder
- Used ABB Pulse Coders
- Allen Bradley Pulse Coders
- Used DC Pulse Coders
- Used Fuji Pulse Coders
- Used GE Pulse Coders
- Used PCB Pulse Coders
- Siemens Pulse Coders
- Solid State Pulse Coders
- Square D Pulse Coders
- Dynapar Pulse Coders
- Stegman Pulse Coders
Search for Low Cost Pulse Coders
- Low Cost ABB Pulse Coders
- Low Cost DC Pulse Coders
- Low Cost Fuji Pulse Coders
- Low Cst GE Pulse Coders
- Low Cost PCB Pulse Coders
Our maintenance forum is jam packed with troubleshooting questions and answer, historical data, and general conversation on almost any topic . Forums are broken down into the maintenance saloon, troubleshooting 101, electrical and electronics, mechanical issues, and the classified ads.SMF file version (2.1.2) does not match SMF database version (2.1.7).
Run the SMF upgrader to fix this.
More information.
We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage pulse coder, to list them at OI. Ad creation takes only a few minutes and is free of charge.
Search Classifieds →About Us
We are a technology based organization. All information regarding pulse coder has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: DC Magnetic Motor Controllers | Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | Proximity Sensors | PLC Hardware | Variable Frequency Drives | Motor Inverters | PLC Racks | Vintage Breakers | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Magnetic Chuck Parts | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps | Electic Motor Tachs
- How much per hour? Here's a cool salary wizard Free to use, search for industrial technician salary info near you. What are your salary expectations? Whether you are researching a new job offer, looking for a promotion, or just want to see what you should be getting paid as a technician.
- A Troubleshooter or Repairman... What is a Maintenance Technician? A maintenance technician will be involved in routine maintenance procedures as well as helping to troubleshoot problems should they arise with equipment in the manufacturing process, assisting in the installation of new manufacturing equipment, and calibration of equipment and routine inspection and testing of machinery. Read more...
- Indu-Bot Histroy: The History of industrial robots, the origin stretches back to the Renaissance, but really started evolving post World War ii with computing advances..
- ABB launches IoT Dashboard AGIBOT, a developer of AI and robotics, hosted the UK AGIBOT Partner Conference (APC) 2026 in London, showcasing the commercial value for humanoid robotics through technology innovation, real-world deployment, and local partnerships.. This is a good read...
