Obsolete DC Magnetic Motor Controllers
DC magnetic motor controllers were an integral part of industrial manufacturing for decades. Precise motor starting had revolutionized the way we make just about every product in an industrial environment. When they operate properly, they provide us with a controlled DC motor operation.
When they fail, they can leave us helpless in a costly situation on the shop floor. However, obsolete DC magnetic motor controllers open up a new page in the book of down-time.
Motor Controller Troubleshooting Tips | Search eBay for Used Motor Controller | Motor Controller in our Forum
OI is user supported. When you buy through our site, we may earn a small affiliate commission, our full disclosure is here.DC Magnetic Motor Controller Troubleshooting
Fortunately, magnetic motor controllers can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete magnetic motor controllers in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available parts for these old dc magnetic motor controllers, we've been referring individuals to eBay. It almost seems too easy but we've found many dc motor strarter parts, relay coils, contact kits, complete contactors, and even some resistors available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradley parts, Westinghouse parts, Cutler Hammer parts, or obsolete GE contactor parts listed daily.
These parts are those that were posted as a result of this technology being replace by modern drives. In some cases the motor controller parts are NOS (new old stock) but in most cases they are used items.
Machine downtime due to an obsolete DC magnetic motor controller is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular DC motor controller is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Motor Controller
- DC Controllers
- 240 Volt Controllers
- Used Motor Controllers
- Allen Bradley Controllers
- Cutler Hammer Controllers
- 480 VAC Controllers
- GE Motor Controllers
- Cutler Hammer Relays
- DC Coil Controllers
- DC Relay Controllers
- Westinghouse Controllers
- Motor Starter Controllers
Search for Low Cost Magnetic Controllers
- Low Cost DC Controllers
- 240 VAC Controllers
- 240 VDC Motor Controllers
- ABB Motor Controllers
- Low Priced Motor Controllers
- 480 VAC Motor Controllers
- Fanuc Motor Controllers
- Cutler Hammer Motors
- DC Magnetic Controllers
- DC Magnetic Relays
- Westinghouse magnetic Controls
- Magnetic Motor Starters
Our maintenance forum is jam packed with troubleshooting questions and answer, historical data, and general conversation on almost any topic . Forums are broken down into the maintenance saloon, troubleshooting 101, electrical and electronics, mechanical issues, and the classified ads.SMF file version (2.1.2) does not match SMF database version (2.1.7).
Run the SMF upgrader to fix this.
More information.
We are a technology based organization. All information regarding DC magnetic motor controllers has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | Proximity Sensors | PLC Hardware | Variable Frequency Drives | PLC Racks | Vintage Breakers | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Magnetic Chuck Parts | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps | Electic Motor Tachs
- How much per hour? Here's a cool salary wizard Free to use, search for industrial technician salary info near you. What are your salary expectations? Whether you are researching a new job offer, looking for a promotion, or just want to see what you should be getting paid as a technician.
- A Troubleshooter or Repairman... What is a Maintenance Technician? A maintenance technician will be involved in routine maintenance procedures as well as helping to troubleshoot problems should they arise with equipment in the manufacturing process, assisting in the installation of new manufacturing equipment, and calibration of equipment and routine inspection and testing of machinery. Read more...
- Indu-Bot Histroy: The History of industrial robots, the origin stretches back to the Renaissance, but really started evolving post World War ii with computing advances..
- ABB launches IoT Dashboard AGIBOT, a developer of AI and robotics, hosted the UK AGIBOT Partner Conference (APC) 2026 in London, showcasing the commercial value for humanoid robotics through technology innovation, real-world deployment, and local partnerships.. This is a good read...
