Obsolete Gear Motors
The gear motor is one of the backbones of industrial manufacturing. It has revolutionized the way we make many products in an industrial environment. Gear motors convert small amounts of power into geared-down motion for a variety of engineering reasons including torque and power. An obsolete gear motor, even in fractional horsepower, can cripple a manufacturing process.
When they operate properly, they provide us with reliable accuracy. When they fail, they can leave us hanging. However, obsolete gear motors open up a new page in the book of down-time.
Gear Motor Troubleshooting Tips | Search eBay for Used Gear Motor | Gear Motor in our Forum
OI is user supported. When you buy through our site, we may earn a small affiliate commission, our full disclosure is here.Gear Motor Troubleshooting
Fortunately, gear motor problems can be fairly simple to diagnose, sometimes the bigger issue is finding a suitable replacement for an obsolete gear motor in an environment of ever-changing technology and design.
For ease of use, accessibility, and available industrial gear motors, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Reeves gear motors, Falk gear motors, Eaton gear motors, or obsolete Dodge gear motors listed daily.
These obsolete items can be a tough find due to the endless combination of gear ratios and motor specs. These parts are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
Machine downtime due to an obsolete gear motor is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular gear motor is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Gear Motor
- Used Boston Gear Motors
- Used 480V Gear Motors
- Dodge Gear Motors
- Used Eaton Gear Motors
- Used DC Gear Motors
- Used Falk Gear Motors
- Reeves Gear Motors
- Sterling Gear Motors
- Sumitomo Gear Motors
- US Motors Gear Motors
- Winsmith Gear Motors
Search for Low Cost Varidrive
- Low Cost Gear Motors
- 480 VAC Gear Motors
- Dodge Gear Motors
- Eaton Gear Motors
- 240V DC Gear Motors
- Low Price Gear Motors
- Chinese Gear Motors
Our maintenance forum is jam packed with troubleshooting questions and answer, historical data, and general conversation on almost any topic . Forums are broken down into the maintenance saloon, troubleshooting 101, electrical and electronics, mechanical issues, and the classified ads.SMF file version (2.1.2) does not match SMF database version (2.1.7).
Run the SMF upgrader to fix this.
More information.
We are a technology based organization. All information regarding gear motors has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: DC Magnetic Motor Controllers | Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | Proximity Sensors | PLC Hardware | Variable Frequency Drives | Motor Inverters | PLC Racks | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Magnetic Chuck Parts | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps | Electic Motor Tachs
- How much per hour? Here's a cool salary wizard Free to use, search for industrial technician salary info near you. What are your salary expectations? Whether you are researching a new job offer, looking for a promotion, or just want to see what you should be getting paid as a technician.
- A Troubleshooter or Repairman... What is a Maintenance Technician? A maintenance technician will be involved in routine maintenance procedures as well as helping to troubleshoot problems should they arise with equipment in the manufacturing process, assisting in the installation of new manufacturing equipment, and calibration of equipment and routine inspection and testing of machinery. Read more...
- Indu-Bot Histroy: The History of industrial robots, the origin stretches back to the Renaissance, but really started evolving post World War ii with computing advances..
- ABB launches IoT Dashboard AGIBOT, a developer of AI and robotics, hosted the UK AGIBOT Partner Conference (APC) 2026 in London, showcasing the commercial value for humanoid robotics through technology innovation, real-world deployment, and local partnerships.. This is a good read...
