Obsolete PLC Hardware
PLC hardware is an integral part of industrial manufacturing today. Programmable logic hardware has revolutionized the way we make just about everything in an industrial environment. When it is programmed and operating properly, the PLC will provide us with very efficient machinery control. When we experience a hardware failure, the PLC can leave us helpless in a costly situation on the shop floor. However, obsolete PLC hardware open up a new page in the book of down-time.
PLC Hardware Troubleshooting Tips | Search eBay for Used PLC Hardware | PLC Hardware in our Forum
Fortunately, plc hardware problems can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete plc in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available plc hardware, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradley plc's as well as many other brands including Mitsubishi, Koyo, Fuji, Siemens, Square D, and many other brands of plc hardware listed every day.
These parts are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
replace obsolete PLC HardwareMachine downtime due to an obsolete PLC hardware is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular PLC hardware is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used PLC Hardware
search for used PLC Hardware
Search for Low Cost PLC Hardware
Search the Forum for PLC Hardware Q & A
We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage PLC hardware, to list them at OI. Ad creation takes only a few minutes and is free of charge.
We are a technology based organization. All information regarding PLC hardware has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
We also posted a PLC hardware troubleshooting guide for those who need help diagnosing a problem.
See also: DC Magnetic Motor Controllers | Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | Proximity Sensors | Variable Frequency Drives | Motor Inverters | PLC Racks | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps | Electic Motor Tachs
