Obsolete Proximity Sensors
The proximity sensor is an integral part of industrial manufacturing today. Precision machinery control has revolutionized the way we make just about everything in an industrial environment. When they operate properly, they provide us with a millions of switching cycles with no mechanical wear whatsoever. When they fail, they can leave us helpless in a costly situation on the shop floor. However, obsolete proximity sensors open up a new page in the book of down-time.
Proximity Sensor Troubleshooting Tips | Search eBay for Used Proximity Sensor | Proximity Sensor in our Forum
OI is user supported. When you buy through our site, we may earn a small affiliate commission, our full disclosure is here.Proximity Sensor Troubleshooting
Fortunately, proximity sensor problems can be fairly simple to diagnose, sometimes the bigger issue is finding a drop-in replacement for an obsolete prox sensor with the equivalent specs in an environment where ever-changing technology and design can phase out, or completely eliminate models from the available parts catalog annually.
For ease of use, easy search and accessibility, and a never ending supply of obsolete proximity sensors, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts suppliers, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradley proximity sensors, telemeqanique proximity sensors, P+F prox sensors, Sunx prox sensors,and many more listed daily.
These parts are those that were posted as a result of liquidation or closing of other companies and in many cases are NOS (new old stock) or gently used sensors.
Machine downtime due to an obsolete proximity sensor is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular proximity sensor is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Proximity Sensor
- Honeywell Proximity Sensors
- Used 24V Proximity Sensors
- Used 120V Proximity Sensors
- Allen Bradley Proximity Sensors
- Telemeqanique Proximity Sensors
- Used Sunx Proximity Sensors
- Used Turck Proximity Sensors
- Used Square D Proximity Sensors
- Electromatic Proximity Sensors
- Capacitive Proximity Sensors
- Inductive Proximity Sensors
Search for Low Cost Sensors
- Low Cost 24V Proximity Sensors
- Low Cost 120V Proximity Sensors
- Low Cost Sunx Proximity Sensors
- Low Cost Turck Proximity Sensors
- Low Cost Square D Proximity Sensors
Search the Forum for Proximity Sensor Q & ASearch the Classifieds
We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage proximity sensors, to list them at OI. Ad creation takes only a few minutes and is free of charge.
Search Classifieds →About Us
We are a technology based organization. All information regarding proximity sensors has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: DC Magnetic Motor Controllers | Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | PLC Hardware | Variable Frequency Drives | Motor Inverters | PLC Racks | Vintage Breakers | Electro-Pneumatic Valves | Electro-Hydraulic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Magnetic Chuck Parts | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps
- How much per hour? Here's a cool salary wizard Free to use, search for industrial technician salary info near you. What are your salary expectations? Whether you are researching a new job offer, looking for a promotion, or just want to see what you should be getting paid as a technician.
- A Troubleshooter or Repairman... What is a Maintenance Technician? A maintenance technician will be involved in routine maintenance procedures as well as helping to troubleshoot problems should they arise with equipment in the manufacturing process, assisting in the installation of new manufacturing equipment, and calibration of equipment and routine inspection and testing of machinery. Read more...
- Indu-Bot Histroy: The History of industrial robots, the origin stretches back to the Renaissance, but really started evolving post World War ii with computing advances..
- ABB launches IoT Dashboard AGIBOT, a developer of AI and robotics, hosted the UK AGIBOT Partner Conference (APC) 2026 in London, showcasing the commercial value for humanoid robotics through technology innovation, real-world deployment, and local partnerships.. This is a good read...
