Obsolete Drum Switches
The drum controller was an integral part of industrial manufacturing in the past. Motor starting and control has evolved tremendously over the years in the industrial environment and the drum controller, in most cases, has become a thing of the past. The drum controller was an inefficient means of motor strating and control. It suffered from continual mechanical wear and arcing of the contacts.
However, obsolete drum switches open up a new page in the book of down-time. Since failure of these units usually amounts to an upgrade, being able to replace wearable contact parts on the fly can at the very least, reduce down-toime as an upgrade is planned and budgeted.
Drum Switch Troubleshooting Tips | Search eBay for Used Drum Switch | Drum Switch in our Forum
OI is user supported. When you buy through our site, we may earn a small affiliate commission, our full disclosure is here.Drum Switch Troubleshooting
For the most parts, human discretion and the human touch was responasible for the speed at which the motor was to be accelerated. When they operate properly, they provided us with a controlled motor starting. When they failed, they could leave us helpless in a costly situation on the shop floor. Some factories still use the drum controller on machinery that is old but still functional, in production but not worthy of upgrading.
Fortunately, drum controller problems can be fairly simple to diagnose, sometimes the bigger issue is finding replacement parts for drum controllers in an environment where ever-changing technology and design can phase out, or completely eliminate this type of technology from the available parts catalog annually. Drum controller contacts, the copper or silver alloy coated conductors, seem to be the most commonly failed parts due to arcing and mechanical wear.
For ease of use, accessibility, and available industrial Drum Switches, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Allen Bradly Drum Switches, Westinghouse Drum Switches, Square D Drum Switches, or obsolete GE Drum Switches listed daily.
These parts are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
Machine downtime due to an obsolete drum switch is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular drum switch is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Drum Switch
- 3 Pole Drum Switches
- 480V Drum Switches
- Used Drum Switches
- Rebuilt Drum Switches
- DC Drum Switches
- Vintage Drum Switches
- Refurbished Drum Switches
- Small Drum Switches
- Power Drum Switches
- 240VAC Drum Switches
- Solid State Drum Switches
- Square D Drum Switches
- High Voltage Drum Switches
- Westinghouse Drum Switches
Search for Low Cost Drum Switches
- 3 Phase Drum Switches
- 480 VAC Drum Switches
- 240 VAC Drum Switches
- Low Cost Drum Switches
- DC Drum Switches
- Medium Volt Drum Switches
- GE Drum Switches
- Open Drum Switches
- Powered Drum Switches
- Siemens Drum Switches
- Low Price Drum Switches
Search the Forum for Drum Switch Q & ASearch the Classifieds
We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage drum switches, to list them at OI. Ad creation takes only a few minutes and is free of charge.
Search Classifieds →About Us
We are a technology based organization. All information regarding drum switches has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: DC Magnetic Motor Controllers | Contactors | Relays | Servo Motors | Stepper Motors | Stepping Motors | Proximity Sensors | PLC Hardware | Variable Frequency Drives | Motor Inverters | PLC Racks | Vintage Breakers | Electro-Pneumatic Valves | Position Encoders | Position Resolvers | Pulse Coders | Reversing Motor Starters | Variable Speed Drives | Contactor Coils | Gear Motors | Relay Solenoids | Electronic Solenoids | Varidrive Parts | Soft Starters | Servo Amps | Electic Motor Tachs
- How much per hour? Here's a cool salary wizard Free to use, search for industrial technician salary info near you. What are your salary expectations? Whether you are researching a new job offer, looking for a promotion, or just want to see what you should be getting paid as a technician.
- A Troubleshooter or Repairman... What is a Maintenance Technician? A maintenance technician will be involved in routine maintenance procedures as well as helping to troubleshoot problems should they arise with equipment in the manufacturing process, assisting in the installation of new manufacturing equipment, and calibration of equipment and routine inspection and testing of machinery. Read more...
- Indu-Bot Histroy: The History of industrial robots, the origin stretches back to the Renaissance, but really started evolving post World War ii with computing advances..
- ABB launches IoT Dashboard AGIBOT, a developer of AI and robotics, hosted the UK AGIBOT Partner Conference (APC) 2026 in London, showcasing the commercial value for humanoid robotics through technology innovation, real-world deployment, and local partnerships.. This is a good read...
