Obsolete Temperature Controllers
Temperature controllers are an integral part of industrial manufacturing today. Precise temperature control has revolutionized the way we make many products in an industrial environment. When they operate properly, they provide us with dreamlike temperature control and accuracy. When they fail, they can leave us stranded in a bad situation on the shop floor. However, obsolete temperature controllers open up a new page in the book of down-time.
Temperature Controller Troubleshooting Tips | Search eBay for Used Temperature Controller | Temperature Controller in our Forum
Fortunately, temperature controller problems can be fairly simple to diagnose, sometimes the bigger issue is finding a suitable replacement for an obsolete controller in an environment where ever-changing technology and design can phase out, or virtually eliminate models from the available parts catalog annually.
For ease of use, accessibility, and available industrial temperature controllers, we've been referring individuals to eBay. It almost seems too easy but we've found many parts available that we thought we'd never find. Even after checking with larger parts houses, we still come back and check here regularly. It is not unusual to find obsolete Watlow temperature controllers, Honeywell temperature controllers, Tempco temperature controllers, or obsolete Omron temperature controllers listed daily.
Temperature control is tricky enough without the issue of obsolete controllers. These temp controllers are those that were posted as a result of hard times at other companies and in many cases are NOS (new old stock).
obsolete Temperature ControllersMachine downtime due to an obsolete temperature controller is a reality for many. There are options, however, nothing is ever easy. Here is a systematic approach, a simple yet effective method in dealing with a failed component that has likely been phased out by the manufacturer and no longer readily available.
5. No positive results? explore other options... If your particular temperature controller is ultimately deemed obsolete and unavailable, you'll need to take the next path of least resistance. This may be upgrade or update your equipment with newer components. The good news is that your machinery or industrial equipment will most likely not need complete re-engineering or a top-to-bottom overhaul to accomodate new components. Adjustments to your system are possible when there is no other choice.
Search for Used Temperature Controller
search for used temperature controllers
Search for Low Cost Controllers
Our maintenance forum is jam packed with troubleshooting questions and answer, historical data, and general conversation on almost any topic . Forums are broken down into the maintenance saloon, troubleshooting 101, electrical and electronics, mechanical issues, and the classified ads.SMF file version (2.1.2) does not match SMF database version (2.1.7).
Run the SMF upgrader to fix this.
More information.
Search the Forum for Temperature Controller Q & A
We also offer free industrial classified ad system complete with a category designed for want ads. We strongly encourage those with individual parts for sale, specifically new or vintage temperature controllers, to list them at OI. Ad creation takes only a few minutes and is free of charge.
We are a technology based organization. All information regarding temperature controllers has been contributed by a community of industrialists. We do not warehouse parts and components, but provide a means for perspective buyers and sellers to achieve their goals.
See also: DC Magnetic Motor Starters | Contactors | Relays | Servomotors | Steppermotors | Steppingmotors | Proximity Sensors | PLC Hardware | Inverters | PLC Racks | Pneumatic Valves | Hydraulic Valves | Encoders | Resolvers | Pulse Coders | Reversing Starters | Variable Speed Drives | Contactor Coils | Control Coils | Gear Motors | Chuck Parts | Relay Solenoids | Solenoids | Varidrive Parts | Soft Starters | Servo Amplifiers | Motor Tachometers
